I'm working on an ancillary belt and pulley kit for small sixes. For A/C, AIR pump, alternator and power steering. Also looking at an A/c delete Supercharger kit or A/C only kit which runs a heavy duty iron bar like Argentinas air conditioned 188 and 221 Falcon sixes had. A strong part which also has a strong idler which would suit either non standard a/c applications or supercharged applications, and would clear large body distributors.
Type 1 : I have the stock 1978-1982 S-shell/Fox and 1979 to 1982 Mustang 3.3 six system pretty well locked down. Its the same as these (82 Granada 1st two, Mustang 2nd one):
Type 2: X-shell for US 250 up to 1980. This is a Monarch 4.1, last year made. Typical of Fords engineering, they swapped air pump and a/c positions between the Fox body and X-cars. 4.1 and 250's generally followed the V8 York or Selectair air con pump position on drivers side.
Type 3: Generic A/C kit for either US or Oz 200/250, but also an M112 Supercharger kit if A/C is deleted.
I'm planning on using the Argentine over cylinder head bracket to hold the A/C unit in the standard V8 postion as per my mates 1979 Indy with 86 5.0 EFI. If needed, it can then be used to hold an M112 supercharger, clearing any distributor. Here are the photos I found on the net which cover my inspiration:
My mates Indy 79 with 86 sefi
Shot 1 and 2 of the Argie 221 SP with 86 V8 style A/C,
Show pic of Falcon with Paton Supercharger in V8 ac position,
and where we all want to be, our first Classic Inlines head with a running supercharger, a Bronco,using the V8 A/c position for its supercharger.
