I've been brainstorming over the past few weeks about a potential project. Right now I don't have a vehicle that I'm comfortable towing larger loads with, say car on a dual axle trailer or a small travel trailer. The Bronco II I have would probably be ok with 5k behind it (5.0L/M5ODR2), but I have plans to rework the suspension on it and install 35" tires. Another goal I have is to build a vehicle for casual bracket racing and Power Tour type events. For that, I have a 351 Cleveland just waiting for a performance build. So here's my idea:
Build a lowered reg cab short bed 2wd bullnose truck with a bed cover and a 300 six built with towing and MPG in mind.
Set the truck up to be able to drop in the 351c quickly for the fun stuff.
For the transmission, I have a 4R70W that I can control with a Microsquirt and have two different tunes for street/performance. The 351c would be built with quick change mounts/harnesses etc. so dropping it in would only take about an hour. There are 10" and 11" converters available that could be slid in with the V8 install as well. I can run an open 9" in the rear and install a spool in a second center section with gears for drag use.
I know there are hurdles such as the water outlets on the radiator and exhaust, and I want A/C, which will take some thought. Right now I need the recipe for the base truck. So far, I'm thinking stock cam, ported head, stock valve sizes, stock compression, Offy C, EFI exhaust, and probably a Motorcraft 2bbl carb, at least to start. I'll lower the front suspension by raising the pivot points on the twin I beams, install air bags and flip the rear axle over the leaf springs. Probably run 17" wheels with a suitable 55 or 60 series tire.
Ideas?
Ideas?
