Well, a few actually. I went to the local junkyard and found a duraspark II dist. but the module was already gone. I was looking around the net and found the HEI GM module which seems like a great way to go. The wiring looks almost too simple. How does this compare to the duraspark? Right now I have the Pertronix Flamethrower coil but was thinking of switching to a TFI coil. How do the two compare? Would this work ok with the resistor wire in place or should I remove it. If I remove it, is it possible to pull too many amps for the stock alternator to take care of? Could I later add a MSD 6AL to a DSII/HEI/TFI setup? Would there be any benifits? I've read a lot from different posts on here and I'm just trying to piece it together. Thanks.
