WOW, so MUCH!! I'll try to keep up...
62-one-ton-falcon":yk9oqj0f said:
IMO:
1 ) Do a large valve conversion with decently heavy porting and a 5 angle. Use the teflon seals when you decide to start, the umbrellas are the worst. Get the guides checked and replaced if necessary with bronze. The head is crucial.
2 ) Check for grooves on the block, either bore or just ball hone to spec. If you have an accurate scale and a wheel grinder, you can balance your own rods, pm me for ideas on that, Ive done hundreds. The wrist pin has to be popped out, but maybe a shop can do that.
3 ) Put a high volume or high pressure oil pump, upgrade that.
4 ) Change ALL seals, gaskets etc. Do it all the way, do it right, do it cheap, and have all the upgrades you can ever want for only slightly more.
5 ) Put a chunky cam in there do research on whats the best for race app with good tall lift and long dur., even research for a good roller system, or if you dont decide on that, an adjustable rocker system is here sitting for donation, all you have to do is buy a set of four pushrods, the other 8 or 9 are here.
6 ) I'd put an oil cooler on it, since that turbo oil gets the whole oil temp high and the pressure low. Use straight 60 oil, and change after every other trip to the strip.
My dad runs straight 70 in his dragster, and dumps it after every run.
7 ) Blows less oil, and some "glue" would help seal those rings. Youll get a more efficient and possibly quicker run once the car is warmed up for 5 minutes, and your compression % will go up sealing the guides, seals and most importantly the rings. 20(?) psi is pushing past some old rings, and hindering your performance. Throwing thick oil in a loose engine is a great way to tighten it up.
8 ) I hope you IC it with something substansial, or even a good route is a front mount Volvo in front of the rad. Volvos are CHEAP at the boneyard.
9 ) With your air inlet idea, be really careful with that. Road debris...well you know. Id disconnect it in transporting it.
10 ) All those ideas combined wouldnt take that much more money, not much more work than youd already be doing, and make it run maybe in the 12.5 or BETTER BETTER BETTER, IMO
11 ) To be honest, I JUST looked at your time slip (it was missing earlier), and your launch needs work or 60ft., the mph is "somewhat" low for that et.
Howard":yk9oqj0f said:
12 ) I hope the tranny wasn't slipping. You are gonna need more rpm or shorter gears to pick up speed. If you are looking at 1/4 mile only, you max out at peak HP and rpm at the line.
13 ) I've read that the stock bottom end is good for 7000 rpm. Is that what you are shooting for? From a system standpoint isn't that related to the cam? I can easily see the stock cam pooping out at 5000.
14 ) I think you should pop for an A/F gauge and sensor.
15 ) The pinging and oil burning sound bad. But it IS running, and hard !!
16 ) I can't tell you guy's how much this impresses me.
17 ) . Here's 2 cents.
1. Build a new stock motor, but build it right. Blueprint (I hate that term) it. Fit your rings, balance your rotating assembly, cc your chambers. get everything as right as it can be.
2. Move up one notch. Build a stock bottom end, ditto above. Use your new rods with stock pistons, but get a cam !!
18 ) A/F is my big worry. I see the carb as the weak link in this whole picture. You just can't really tell what is happening unless something blows up.
1 ) Getting the head done right is a huge priority. A great engine with a crappy head will run like a crappy engine.
I plan on bronze guides and stainless valves.
2 ) The next block I have is standard bore, no ridge.
It will be honed straight and true a few thousands larger and standard forged pistons are ready to go in (you need to go back and read the thread again)
3 ) I have never seen a HV oil pump for a 200.
4 ) I have, like, 5 gasket sets already? (go back and read the thread again
5 ) I bought and received and have ready a FSPP 214*/214* @ .050" cam (go back and read the thread again
6 ) It doesn't get that hot in 13 seconds!
I use Shell Rotella T 15W-40 weight with 1/2 quart of Lucas oil stabilizer.
7 ) I don't think thicker oil will help at this point.
8 ) I HAVE a FMIC (go back and read the thread again
page 1! )
Volvo intercoolers grenade over 15 psi and are just barely enough for 2 liters and are completely worthless for what I am trying to accomplish (read: WAAAY too small!)
9 ) I plug it with a piece of foam when not in use - is for track only.
10 ) Just a super 60 foot would get me in the 12's!!!
11 ) For the 1/8 th, no way. For the 1/4, yes.
A guy with a firebird was running 13.6 at 106 - he was pissed I was faster than him! ( a couple posts up - go back and read
12 ) Tranny was not slipping, it was working perfectly!
I am not going to change gears (that is way too much hassle and money involved!)
What I NEED is more RPM's in high gear.
13 ) I'll take what ever I can get RPM wise. The stock cam - - - when testing this engine N/A with a freshly rebuilt carb - - - topped out at only 4,000 RPM. That was it. The boost is good for another 1500 RPM on top of that.
14 ) I have one ! (go back and read the thread again
15 ) It was terrible on the last run, and I hit 10 psi on the return road and it was pinging. This motor is worn out.
16 ) I am impressed myself!!! I NEVER, EVER thought I would make it this far!!!
17 ) I already have forged pistons. The new rods (look up a few posts - - pic ) are on their way. I have new bearings and rings. I have a cam - - 214*/214* @ .050"
I will be checking all clearanaces closely. I do plan on balancing it.
Oh yeah, just one more thing for y'all - - - - - - - - - - (go back and read the thread again
Thanks for all the comments....More to come!!! AS ALWAYS!)
Linc
