Sure this has been covered and I just missed it but: Is the valve train for the argie head the same as the US? What ratio are the rockers, how big are the valves? Are the springs the same? Thanks, Matt.
It uses all the same stuff as the US heads. You should have no problems. Your particular head is cut for 1.69" intakes and 1.39" exhaust valves. You can either use stock valves from a 1971 Maverick (for example), or you can enlarge the seats for larger ones.
