Here's pictures of the Aussie 2v intake after grinding and polishing, the carb is a Holley 650 cfm, this next week Little Roo and I will install it on his 65 Mustang and see what we get..
The spead bore has be rebuilt, we don't think the square bore has been rebuilt, but we are going to try both carbs or locate another carb, 390,450 or other 4v to mount and try!I notice 2 different carbs a square bore and a spread bore are you going to test them both for us or just decide which one you think works best and go with it?
No it's not welded, the 650 spread bore fits without a spacer, the linkage barely clears the intake. The riser is for a square bore and we may try it with and without to see which is better for the street.is that spacer welded to the manifold? i was just wondering because i want to turn my carb like that.
From www.mustangandfords.com
You can read ’em and weep for a couple of reasons. Weep because Ford inflated the factory horsepower numbers. As you’ll see, our collection of muscle Mustangs didn’t uphold their reputations as some of the badest muscle cars ever built. With the advent of the Dynojet chassis dynamometer as a valuable tool for accurately measuring a vehicle’s rear-wheel horsepower and torque. From the rear-wheel numbers, we would be able to extrapolate, using Dynojet’s percentages for drive train losses, the actual flywheel horsepower and torque measurements. For a manual transmission, Dynojet calculates a 17-percent loss. For a non modified automatic, it’s a whopping 25 percent. Interestingly, the torque numbers from our test came closer to the factory ratings than the horsepower figures. Horsepower, however, averaged 62 lb-ft less. Does this indicate that the factory provided fairly accurate torque ratings but fudged on the horsepower numbers during the highly competitive muscle car wars?
Stock '70 Mustang Convertible:
302-2V HP to the rear wheels, dynojet 112 hp
Weight 3,340 lbs
Front weight 1,980 lbs
Rear weight 1,360 lbs
Original 8-inch axle ratio 3.00:1 open
0-60 MPH 12.46 seconds
1/4 Mile Time 18.89 @ 74.4 MPH
