shineycrab
Hello all
I have a 68 Mustang with the 6-Cyl 200CID with an OEM Ford Autolite 1100 carburetor, all original. Just finished a complete restoration. I’m new to this engine and carb; all my previous Mustangs were V8 w/ 2BBL carbs.
The problem happens after the car sits for more than a few days. It takes a lot of cranking to finally get the fuel bowl full, then she starts right up. I’ve confirmed the bowl was empty by looking in the carb throat and hitting the accelerator…no fuel squirting. When I shot a syringe full of gas into the fuel bowl vent, she fired up immediately. The fuel pump is brand new, the carb was just rebuilt and the float set. She runs beautifully once it starts. I’ve had other Mustangs (again, V8 & 2BBL carb) that would sit for weeks and fire up immediately.
Is this a known issue with Autolite 1100s? Can the fuel bowl vent adjustment cause gas to evaporate quickly? Some online forums say a valve in the fuel pump may be allowing fuel to leak backwards?? I recently had the carb off the engine and the inside of intake did not seem wet from fuel leaking in that way.
Any help would be appreciated.
