candyapple66
Active member
Hello-
One thing that I need to fix is the front part of the lid of my autolite 1100 carburetor does not fit flush at the leading edge. I believe the top has warped so it wont sit flush against the new gasket I put in and as a result gas spews out from that spot. The old gasket had swelled to fill in this gap but it is about a 4 mm gap.
What would be the best method to flatten the lid. I know that ive heard people who bolt the lid onto a piece of strong flat steel and heat the lid in that spot and hammer it flat but I wanted to check with you guys before I did all of that.
Thanks!
Thanks!
Sounds good to me.
