Ah. I'm not sure of the post 2002 BA engines, which is the topic of the conversation, but the 1982 to late 1984 XE Falcon was BMW 3 and 7 series Bosch Motronic LE-II on 4.1 liter X-flow, and it is different to the Ford EEC's normal US and Aussie '79-'02 8000 pulse per mile system. The XD/XE lookes to be a 6000 pulse per mile sensor. It is, after all, a non O2 sensored leaded fuel engine, and doesn't have a close loop feature, nor employ a VSS. Thats why it doesn't follow normal US Ford electronic practice.
:wow:
The EEC III, EEC IV and most EEC V's require an 8000 pulse per mile vehicle speed sensor signal from the PSOM (speedo module), which is just like all other EEC-IV equipped vehicles
Other later EEC V applications use a 16000 or 40000 pulse per mile VSS signal.
My Fox has a Ford VRS (variable reluctance sensor) speed sensor, an 8 pulse per revolution VRS sensor which is conditioned by the output shaft from the transmission, and mouned on the speedo cable as per standard Fox practice, to allow the EFI, cruise control or fuel consumption meter which became Fox options on other models to work.
For the rare occasions that the Thunderbird, Lincoln Continetal or LSC or Fox came with an EEC III 5.0 CFI, or the more common EEC IV 2.3, 3.8 or 5.0, the speedo expects to see a set amount of speedo cable revs at any speed. The old mechanical speedos by GM, Ford, and Chrysler use a set C factor for odometer and speed, so any Fox sensor is preconditioned in the following manner.
An 8 pulse per revolution VRS sensor on a 5.0 auto with 2.73 axle LSC or Tbird or Mustang with 215/60 15 tires with 728 revs per mile would be seeing an 1.365 overall ratio , as it has 8 teeth driving, a maroon16 teeth gear driven, and at 60 mph (96.6 km.h) jammed in non over drive third, it would be turning the 8 pulse per rev speedo shaft at 7949.76 pulses a mile. Or at any speed, in any gear, since the speedo sensor only measures drive shaft speed, not engine speed. So 728 wheel turns per mile times 2.73 final drive turns each wheel turn times the 8/16 drive to speedo gear ratio, times 8 pulses per speedo shaft rev.
Speedo Gear = Drive Gear Teeth X Axle Ratio X Tire Revolutions Per Mile / 1,001
final drive (axle) ratio in 1:1 top divided by (driven speedo gear/drive teeth)=1.50 overall ratio required at 667 revs per mile or 30.22181" of loaded tire
final drive (axle) ratio in 1:1 top divided by (driven speedo gear/drive teeth)=1.25 overall ratio required at 801 revs per mile or 25.1846" of loaded tire
final drive (axle) ratio in 1:1 top divided by (driven speedo gear/drive teeth)=1.00 overall ratio requiredat 1000 revs per mile or 20.1484" of loaded tire
Some trucks (the F450/550's, not the F-150/250/350) have good old iron E4OD extension housing with an out put shaft speed sensor which don't get screwed up with reverse or low range, and you can condition them to suit EEC 3, 4 and most EEC V with a custom 3teeth or factory 18 teeth reluctor. This result is a perfect 8000 pulse per mile (PPM) signal to feed to any of the normal EEC 3, 4 and 5's and also the Ford Cruise Control module.
