Daves55Courier
223 engine was running great, then suddenly backfired for the remaining 20 miles to home. I took off the distributor cap. Both advance return springs are still attached and the vac advance actuator arm is still attached to the breaker plate. I disconnected the hose from the vac advance and hooked up a MityVac. The vac advance is working properly with the MityVac. Can something be broken inside the carburator causing this.
Engine still idles smoothly, but backfiring begins any time you try to accellerate.
Any ideas ???
Any ideas ???
