I'll look @ that. I set the initial with the vacuum disconnected at a good low idle. Although it makes no difference @ idle whether it's hooked up or not. The shifter is fine, no different than stock except for that I'm using a push pull cable and lacking the gate to keep me out of sliding it into R from N, OD, D etc. Today, I drove it in 'D' and found my problem. It's skipping 2nd gear. That's why I thought I was feathering it into 3rd before, but you were right, that was OD. I can't perceive more than 1st then 3rd. If it is going into 2nd at all it's only slipping in and right on to 3rd, but for all I can tell it's just skipping it. I read about and did the 1-d-1 shuffle and got it to go into second and hold second until I shifted back to D and it went into third. I did it a couple of times. This seems to be the main problem now that needs to be remedied before anything else is addressed. It's the reason for the pinging on hills sometimes, it's loading the engine down b/c it's skipping 2nd gear. Thanks a lot for your help, you've save me a bunch of time figuring this out so far. Any idea's on what the problem may be with the aod? Is it toast? I've read everything from governor to valve body to intermediate clutch band spring thing etc. I'm not the first person to have had this problem with an aod apparently.
