Do a quick under hood check for loose vacuum lines or other loose parts like the carb or distributor.
I have torn apart a few too many carbs and engines due to bad gas. Most areas in the us are now using ethanol in the fuel so you have to be careful how much more crap (alcohol) you put in there. It could also be that you got a tank full of extra 'green' gas. There is a gas station chain in my area that claims they are extra green and have all the best additives to save us all, bottom line is my new cars get worse mileage with them and my old cars run like total crap, hard starting, vapor lock, rough idle... So if your last tank was a different than usual station for that car that could be the issue.
