crash-harris
And I'm about to do it too. Thinking about putting a turbo on my EFI 300 when I finally get to start building it up. I'm planning on punching it .030" over to clean it up, new nearly everything, cheb rockers, guideplates, metal timing gears, Comp Cam 252, advance the cam 4*, Keith Black forged pistons, about 9:1 CR, mild porting, and if I turbo, a MS to replace the ECC-IV and I may have to grab some 19 lbs./hr. injectors. I haven't looked into turbos too much but have always wanted to turbo a six. The wall of iron will get dropped in the '90 F150 to take the place of the tired and abused stock 300. I've heard that turbos from 6.5L Duramax diesels are a good match to low end on a 300. The truck is a DD and I'm building it for the trail, mud, and maybe some rocks if I ever find some the right size around here. She works a lot though, clearing trails, pulling trees, etc. Would you guys mind posting/linking some pics of your turbo 300 setup and some info? Since it will be on a DD should I keep the boost under 10 psi or so?
