BELLHOUSING
I HAVE A 69 FASTBACK WITH A 200CID C4...I WANT TO SWAP TO A TOPLOADER THAT I ALREADY HAVE. I ALSO HAVE A 4 SPEED BELLHOUSING SIX HOLE THAT I WAS TOLD FITS 289/302. CAN I MAKE THIS WORK ON THE 200......JUST WONDERING EVEN THOUGH IT SEAMS OBVIOUS THANKS
You need a bellhousing from a 200 or 170 from a 1967 or later version equipped with a "3.03" 3spd transmission. You'll also need the matching 9" flywheel/clutch combo. The toploader will bolt right up.
