best spark plugs for pertronix ignition
Is it worth buying any of the 2 pronged or 4 pronged spark plugs out there to go with the Pertronix ignitor and flamethrower?
Thanks,Spence
If you are referring to those Bosch type +2s or +4s, they won't fit on a 200 cid / 3.3L (trust me, I have looked). I do run the +4s on my 5.0 though :)
However you also have the classic Splitfire (like what I use with my pertronix stuff).
Then there are the ones made by NGK. The best pictures I could find are http://www.mfgsupply.com/m/c/BR9EYA.html?id=36RBLrxq
Personally, I'm still running stock plugs. I had splitfires once, made my car run worse. Just get regular cheapos and open to the gap to .045 or so.
Slade
You can either go to a race shop and get some HP spark plugs from them or run the bosch platinums (you can get a set of Bosch platinum plugs from Advanced for about $8 - $12). I had the Bosch platinum in mine then moved to the racing plugs in it after all my upgrades - don't know if they made any difference though.
