Big 6 efi intake Flip
Anyone ever tried to spin the efi split manifold around to move the plenum to the passenger side and possibly adapting it to fit a 4 barrel?
This idea intrigued me at least
I have seen severial carb's mounted on the modded EFI pentiums in its stock location and that seems to work ok. Also seen a few custom carb plentiums built using the bottom section of the EFI intake this moves it over quite a bit there are pictures of a couple of these by FTF on this site showing there details, I am of the OPIN that this works much better for a carb application. I have never seen anyone do what you are proposing yet I sure that it could work but I have to wonder if it's a very good idea putting the intake pentium that far over the hot exhaust side of the engine? You certainly could try it to see if it works for you. Best of luck :thumbup: :nod:
If you look at you lower manifold in the bend you could cut it and flip it around. be careful casting is fragile I broke mine doing this- not learned SLOWLY yet! Got to learn to weld AL.
