TrickSix
Large log carb spacer for head with 1-3/4" inlet. Comes with mounting bolts and carb studs and nuts.
Aluminum thermostat housing with threaded port for extra temp sensor. Comes with bolts, gasket, extra port plug, and 195* thermostat.
Homemade adapter to put a large log carb on a small log head. Nothing fancy, it was made from a '68 pipeless carb spacer just to test an 1101 carburetor I'd picked up. The bigger carbs have a longer and wider base so the steel oval plate in the middle between the two gaskets is to increase the width of the upper surface enough to cover the whole bottom of the carb flange. A phenolic spacer could do the same thing and add some heat insulation as well. I thought I might have heard some gas boiling in the bowl after driving the car on a hot summer day. The car ran fine and I was just testing the 1101 for a couple days so I never looked further into the matter.
$50 plus $12 USPS shipping in the USA for all three items. A possible issue - Despite years spent working in a high-tech industry, I'm a technology hating old fart. No PayPal, no Venmo, nothing like that. You'll need to send me a check or something.
