I got a new set of adjustable rocker arms with pushrods to go on my granada head on 68 200 block. I installed them but now have big probs with adjustment!
I line up the timing marks on the engine and took off the diz cap to find it at #1. I adjust the nuts on the rocker arms for the #1 cyl but there is still slack even when I crank them down all the way. Basically I can not get them tight plus one turn. I run out of thread.
Engine is cold and has not run for several months. Does the engine have to be warm to have the lifters pumped up. Could it be my cam is worn down that much? Engine ran well before just had starting problem and carb issues, so i am switching carbs and heads.
Any help would be great
