First off, are my carbs turned the wrong way? I gotta say I think I dont have it set ip properly cause with just the middle carb running till I stomp on it I have no power with just one carb. When the other two open its pretty nice. It didnt add as much power as I expected, but then again I think something isnt tuned correctly. Anyone have any suggestions? Well anyway I also added a Mallory unilite distributor, an electric fuel pump, and as you can see the offinhouser tripple weber setup. I also have a clifford 280 cam, Rhodes variable bleed lifters, dual valve springs w/titanium retaners, exhuast port devider, just to be safe the engine rotating assembly was fully balenced.
[/img]
[/img]
Let me know what you all think.
James
[/img]
[/img]
James
