I've done a bit of research on axial fan electric superchargers (axials are the only ones that can push the CFM a real engine needs). As mentioned earlier, these fans can push upwards of 1000cfm sometimes, but 1lb psi is the BEST you can hope for, and while it sounds like a good idea... its a wot only device and the risks of having it in your air path are just not worth it.
The design of an axial supercharger has roots in the 60's from jets where like 13+ thin metal fans would be used to compress air step by step to increase performance. A single fan cant do this, and many fans... may, but arent designed to so i wouldnt count on it. And the cost... at about 13 of those things, would rival the cost of a turbo or supercharger.
My theory on these things however is not to use them as a power adder, but as a negative pressure reducer for a boosted system. BIG gains have been found on cars by simply reducing the vaccuum of the intake system pre-compressor, mostly in stock boosted cars since factory air boxes and such leave a lot to be desired. So my idea is to take your K&N intake just like normal, but Y the intake into the axial fan and 2nd filter. This way the fan can never obstruct normal driving airflow, but when the WOT switch is triggered, the fan supplies air with no vaccuum which is easier to compressor and makes power more easily. I may test this when I turbocharger my cougar. At that level, it may be an easy $50 big hp adder, or simply annother $50 wasted, we'll see.
