Info appreciated on instructions for modifying a Ford small block six mechanical fuel pump for boost referencing. Latest project is a Supercharged Bow-Through Carburetor setup and want to modify a mechanical pump for boost referencing.
thanks
Ford small block six 250/Vortech V2/ modified Holley 2300-350/Maverick 3OTT Toploader for awhile...
Wired up an electric pump relay with safety oil pressure switch for the Maverick but still need to install a return line for a TB fuel injection type @45 PSI electric pump with bypass type Aeromotive Fuel Pressure Regulator with boost reference port.
thanks
.Wired up an electric pump relay with safety oil pressure switch for the Maverick but still need to install a return line for a TB fuel injection type @45 PSI electric pump with bypass type Aeromotive Fuel Pressure Regulator with boost reference port.
