LameHoof65
Well, I thought about bundling the block with crank, pistons and rods into the machinist to have the bearings/bushings replaced---But then I thought--they look pretty easy to replace--why waste time and money on a machinist? So,, I start trying to locate the cam bearing install tool. No one has one, Oreillys, Autozone, Pep Boys---So I thought how about buying one---and one was all I could find and it lists for $150.00. A little steep for a tool you may use 2 or 3 times in a lifetime---So then I talked to a friend who has every tool known to man and some not..He has done a bunch of rebuilds and he says "That is the one tool I don't have---I always let the machinist do that---I suggest you do the same." So, now I am thinking---crap do I really need to install these bearings...Addo has made some good points about why not too and others have made some good points about why I should....Seems the big issue is marring the cast iron where the bearing seats or getting a seat in crooked or not getting a tight fit or having it fit without at least 75% direct hit on the oil holes. :roll: Yes, I know "Darwin just make up your mind and go with your decision!!!" Would you--or wouldn't you try this yourself, if it was your first go at an installation of the cam bearings?
