This question is mainly directed at Does10s. Would it be worth the effort to advance the cam one tooth on a '73 stock 250 cam when using a small turbocharger, currently at 7 psi, with plans to go to 10psi? I am assuming my '73 is equipped with the emissions-retarded version of the timing gear, can you verify this? Is advancing the cam done to close the exhaust valves sooner to reduce the likelyhood of reversion? Will you please elaborate and also share your thoughts on the possible gain on my meager set-up: stock longblock with turbo, intercooler, 16 degrees initial timing with 10 mechanical advance, and possible water injection if needed due to future detonation?
Thanks! -Joe
Thanks! -Joe
