kboldin
So I’ve read a ton on cams over the past few weeks and the more I’ve read, the more I get numb about all the variations and possibilities there within. I have gathered an all-around street/strip cam is a 264/2642@112* Hydro (for the 200ci).
I understand how many have come to the conclusion that this is a decent compromise between performance/idle quality/power/vacuum etc… Where I start getting off in the woods is the correlation between hydro and solid lifter equivalents, that is, if there are equivalents?
Looking at the different vendors who produce cams, it seems there is a common correlation between hydro’s and solid lifters were the solid lifter cams consistently start with a higher duration among cam grinds offered.
From my reasoning (likely flawed) a solid lifer cam 264/264@112* should be identical to a hydraulic lifter cam 264/264 @112*. The lifters (hydro and solid) should be identical dimensions when the hydraulic lifter is fully “pumped” up.
If that’s true, why is there consistency between manufacturers who start solid lifer cams at such a wider duration? (example: clay smith hydro’s start at 264/264@108*, their solid lifter cam starts at 278/278@108*. Among the manufactures, going to their sites, they are all virtually the same.
Maybe I’m making a mountain out of a mole hill but I’d like to understand the difference and I'd rather use a 264/264@112* solid lifter cam rather than a 264/264@112* hydraulic lifter cam (all things being equal).
