62Ranchero200
Just sharing some of my recent experiences on degreeing a cam on a small six:
Doing this accurately is one of the most difficult things I have ever done.
Head on or head off - from what I've seen, it's essentially no difference: at least with high lift cams, for me it was not possible to get an accurate reading on the valve stem, retainer, rocker arm or adjusting nut, so if I wanted to degree with the head on I would pull the rocker shaft and degree with a pushrod on the lifter. However, degreeing seems more accurate with a solid lifter (unless you stack a hydraulic lifter with washers or otherwise immobilize it), so if you'll be running hydraulic lifters you'll need to pull the head to temporarily insert solid lifters. If you're already running with a solid cam and lifters, and you just want to degree to check the specs on a cam you plan to continue running (as if, for example, you purchased the car or engine and wanted to verify the specs), you could certainly do that with the head on, pushrod on a solid lifter.
Pushrod on a lifter is also how I would degree with the head off. Some, including my machinist, suggested dial indicator extension on a lifter; but I definitely had more repeatable results with the dial indicator on a ball and cup pushrod, which was on the lifter. This could be because the dial indicator extension is smaller and moves around in the top of the lifter; or maybe because the lifter rotates and is affecting the dial indicator somehow as it rotates, whereas perhaps the ball and cup pushrod doesn't rotate, or doesn't rotate as much.
The commonly available cam degreeing kits are not all that suitable to precise measurements: every tiny change you make in the dial indicator's mounting throws off the zero on the indicator drastically. Someone "should" make a dial indicator mount with rack-and-pinion type adjustments in at least two dimensions, rather than having to loosen clamps to make adjustments.
If I ever perform another cam upgrade, I'll get a "cam indicator", which fits into the lifter bore and includes a very large cam follower, such as the following:
Bob
Bob
