G
82 250 with stock Weber ADM.
Float bowl is full of fuel. Idle solenoid opens when the key is turned to on. The fuel can be seen squirting into the carby when the throtttle is opened to prime the engine. Engine starts and runs for a few seconds then stalls from lack of fuel. If I drip fuel into the carby after it starts it will stay running.
I am not at all familiar with this carby and don't know how to adjust the idle fuel mixture. Can someone tell me where the adjustment screws are located and at how many turns open would you set them to start tuning the engine? Any other sugestions on what I might check would be appreciated.
David in Dayton, Texas
