Bradbutlernc
Alright so i searched around on here and did some research on the choke adjusting, as well as read my gpsorensen papers on setting the choke, and i just cant get it right. Basically the problem im having is the car wont start with choke, but once its started with fluid it idles fine with the high idle speed, and the plate opens properly too and then idles down to normal. The choke plate is set to have 3/16 of clearance like the manual says, and the choke coil is 1 notch toward lean.
If i spray a little starting fluid in the carb, it fires right up and idles fine, and the choke opens slowly as it heats up, just wont start for crap without it. But once its warmed up once in the morning, it can sit all day and fire right back up when i crank it.
I tried setting the coil one notch toward rich, and the car ran like complete crap and the choke plate wouldnt open at all. Today im going to pull the choke tube and see if i have flow through there, i believe its leaking exhaust into it but im not sure, but i read that was something to check out. When i rebuilt the carb the choke coil was full of sut and crud, maybe a sign that exhaust is getting in it? Im just gonna crank the car and see if i can feel exhaust blowing out of that hole.
Also i read about getting a universal "choke stove" and clamping it to the exhaust, this looks like a good idea, but ive never seen anything like that. Where can i find one?
You guys have any ideas on what i can try next to troubleshoot it? :|
