Hello guys, looking for some carb help. I'm working on a 74 maverick with a 200 and someone tried to rebuild the carb but it was leaking from the front so I pulled it apart and I'm not sure if I got it back together right. Its not squirting when I hit the throttle. I know when I had the top of the carb off with gas in it and pulled the thottle fuel went from the bowl up to the top. From there I'm not sure... I believe the carb is a carter 1v, it says autolite by carter or vise versa on the side of it.
I'm stumped and its fix this one or see if a 1bbl from a 79 fairmont with a 200 will work.
