Titleist16
My 78 engine is at the shop right now being put into my 62 Comet and the guy says that the bolt holes are spaced farther apart than the ones on my old 69 engine. I never heard of anything like this so I went down there and sure enough they were farther apart so now my carb won't fit on it. He said he can drill some new holes on there so that my carb will be able to fit. Has anybody ever heard of this happening before? Also, my vacuum advance is bad and I need to know if there i diference between the vacuum advance on the load o matic dizzy and a regular dizzy. I don't know which one I have so I need to make sure if they are different. Also he said I can put a vacuum canister in the vacuum line of my fuel pump and it will make my wipers work better, is this true? Thanks.
