Carb question? Flat spot
Quick question, I have the Carter YF on my 69 200 with the Petronix. It runs great! But if I punch it off the line, I got a flat spot then acceleration. Any suggestions? If I punch it while moving, its fine. I would like to improve the off the line takeoff.
Thanks,
Maybe rehook your vacuum adavance to manifold vacuum. Give it a try (cheap to play with).
Adam.
I'd try retarding the static timing about 2 degrees.
If it helps, try to get lighter springs in the distributor, at least the primary spring.
