I recently rebuilt the factory Autolite 1100 on my '66 Mustang 200 automatic, and I set all the initial settings per the shop manual. Only the idle speed and idle fuel mixture have been tweaked slightly from the initial settings, and it runs well in general.
My problem is that although it idles well, when I just start to press the throttle, it tends to sputter. If it makes it past this to a higher RPM, it runs great, until I have to come back to a stop and go through the extremely light throttle section again.
What could be some possible causes of this behavior? Is this the "flat spot" that the 1100s are notorious for having?
