carb usage for the aussie head
will an autolite 2100 2bbl (the 289's stock carb) work with the holley adapter on the aussie head for a 200? these carbs seem like they're more readily available for cheaper...
thanks
-rob
Thanks for the head's up! :D Hi-ho, hi-ho, it's off to the junkyard we go...
-Rob
Which Holley adapter do you use to adapt the carb to the 2V intake?
You need the ACL 2V gasket set too, mate!
The AUD$30 Redline "Holley to Stromberg" adaptor from Rare Spares, Sydney. Maybe a Holley to Weber adaptor for a Pinto(?) would suffice with a little persuasion, if you shop more locally.
Cheers, Adam.
