Old Ford Blue
Hey guys first post here, and let me start off by saying that this is an Awesome group yall have got goin here!
Now for the ride in question. Its a 64 Ranchero with a 69-70 200, with a ford-o-matic. The old girl is in really nice shape and has nearly 435k (yeah thousand) miles on it. The 200 only has about 385k on it, since it was replaced by the dealer in mid 70(originally a 170-never ran right).
Anyhow, it still runs excellent and the tranny shifts smooth and right on time.
Now for the question about the ride in question(if that makes any sense).
(Carb #1)I just rebuilt the Carter YF that was on it(had a toasted accl pump), well when I put it back on it worked perfectly, except that unless you babied it to get it off idle it would stumble, not terribly, but you couldn't punch it. So I pulled the top plate off and noticed that I couldn't get the accl pump check ball out of its hole, well theres the problem.
I still can't get the ball out.(ideas welcome here)
(Carb #2)I also had another old YF laying around, so I cleaned it up and threw a kit at it, bolted it on and now everything is working great except the fast idle.
This carb will not fast idle, the other one worked fine, but I can't see anything to make the YF have a fast idle?
What makes it happen?
Carb #2 had some sort of solonoid attached to it that I remover since the other carb didn't have it and Randy has no wire for it.
Thanks in advance for any help yall can give me.
Gabe
Gabe
