$100 EFI?
This is an adaptation of a junkyard Bosch L-jetronic and a Ford Tempo/Escort throttle body to an MG. Click on the L-Jetronic link.
The Ford TB is a two bolt affair that is a direct bolt on to a 1 bbl carb base. It has an integral fuel pressure regulator and injector. The injector is normally run on 30-35 psi, but can be operated at 50-55 psi to increase fuel flow. The air horn is held on with four screws and can be turned to whatever direction is best for your application.
You'll need to add a WOT enrichment switch and a fuel pump with a return line.
L-Jetronics were found in darn near every BMW, Renault, VW, Volvo.....almost everything European in the 80's so this stuff should be very available for next to nothing. The throttle body is a mid eighties piece.
I think this setup is going to be horespower limited, but it should be capable of handling enougyh fuel and air to make around 150 hp, or about what a good running 200 would make. Add a hot ignition system like Mike's DUI and it should be a good carburetor replacement.
