All Small Six Weber 38 issues
CWT1129
Hey guys,
I recently installed a Weber 38 via adapter on my small log 200. I am running a DUI dizzy, dual outlet header w/ dual exhaust. After my first drive, I noticed some gas drip out the carb near the throttle shaft screw. Would this be from dumping fuel or heat soak? I waited a little bit, it struggled to restart, after it did, I took it out once more ans it seemed like to would bog around 55-60 mph. I called Clifford and Weber and got mixed opinions. My fuel regulator is set at 3 psi. New fuel lines with filter prior to the carb. Any thoughts?
