AzCoupe":1b5zwuxr said:The IAC, TPS, Central Vacuum for Power Brakes, and the MAP Sensor Vacuum are all built in to the Throttle Body!
Broncitis":1b5zwuxr said:Its a modified GM TBI with twin 42MM butterflies
218224turbo":1grr1bxr said:AzCoupe":1grr1bxr said:The IAC, TPS, Central Vacuum for Power Brakes, and the MAP Sensor Vacuum are all built in to the Throttle Body!Broncitis":1grr1bxr said:Its a modified GM TBI with twin 42MM butterflies
I believe that Dodge Magnum 5.2L and 5.9L engines (92-04) had twin 48mm butterflies and also had IAC, TPS, and MAP in the throttle body. I'm just curious, is there something special about this throttle body? What am I missing?
350kmileford":ft5obd9b said:I'm pretty sure it's an Eaton M90
