kspageddie
My Duraspark upgrade is finished. Can't believe how quick the car starts. The idle has smoothed out too. I have not increased the gap in my plug yet and they are still at .035. I am going to put new plugs in tomorrow and gap them at .050 to start. I will adjust up and down from there. I am using an HEI module (which was easy to wire) mounted on a plate of 1/4 aluminum. I used a chrome Blaster 2 coil which I mounted on the shock tower just below where I mounted my HEI module. I have the vacuum advance hooked up to the manifold vacuum port. I had the Duraspark recurved by www.reincarnation-automotive.com. Here is the advance chart.
500 RPM Degrees of Advance 0
1000 RPM Degrees of Advance 2
1500 RPM Degrees of Advance 8
2000 RPM Degrees of Advance 12
2500 RPM Degrees of Advance 18
2800 RPM Degrees of Advance 20
Initial timing to 14 degrees BTDC.
I will set up the plugs this week and start to tune the carbs better.
I will begin the biggest project in a few weeks, Rear Frame Rails..
