Well, I'm sure you probably have read I've been having some valve train issues...if not, long story short...something is ary and I believe it to be valve springs. That's a whole nother topic unto itself.
I decided to do a compression check tonight because after the rocker arm bolt broke last week and I fixed it, she just doesn't seem to have quite as much pep. I feared a blown headgasket and I may be right. Here are the results:
Cyl # Compression Reading
1 130
2 180
3 140
4 160
5 180
6 180
Anyone want to gamble where the blown part of the gaskets are. My wager is on the outside of Cyl #1 (since #2 is fine) and between 3&4. The odd thing is that the rocker arm that I lost was the #2 cylinder!
it should be noted that I decided to check the headbolt toruqe before this test and the needed re-torquing a bit. A couple needed quite a bit. The reading above were after the retorquing. The reading before it were slightly and consistently lower across the board (except for #1...didn't change).
Would you say that it is safe to bet I've got a dead head gasket even though she's not running way hot nor do I see any foam or oil in the coolant? OR (now back to the valve spring issues)...
if #1's springs were really bad in comparisson to the rest, would it be possible that that could be causing the readings? If say for isntance, when I adjust the valves on #1, the weaker springs aren't holding the preload pressure and instead are cracking open a bit. Possible?
My plans are to pop new springs on ASAP. I guess I'll have a definitive answer at that point. i just wanted to get the opinions of the group on it.
Thanks all.
1 130
2 180
3 140
4 160
5 180
6 180
Thanks all.
