michael_cini":10eh38m8 said:Wow, that sounds like alot of work. I think pulling the head would probably be less work!
Probably for normal people, but I can't leave stuff alone. If I cracked the motor open... while I'm at might as well lap the vavles, since I got the valves out might as well clean up the valve pockets, heck might as port the exhaust, clean up the flashing... well you know, I can easily change cams while the heads off ...a little extra power towing the boat wouldn't hurt. on & on.
So, you see it is less work doing the way I just did.
