65_Stang_170
Howdy!
I have a leak coming from the water pump. It appears to be coming from the lower left bolt and leaking down from there. I drained the coolant, and put thread sealer and teflon tape to help plug the hole, but it seems it didn't work (actually looks to be leaking more). It also could be leaking more because I filled the coolant up to specs (it was low probably from the leak...).
Anyways, suggestions for helping seal the bolt hole?
Also, best way to get "all" of the coolant out of the water pump? I previously drained through the peacock, and blew through the system to try and get it all out. However, there was still coolant lightly seeping from that bolt hole. This is probably why the thread sealer didn't work...
Thanks in advance!
-Shawn
Thanks in advance!
-Shawn
