Less than a year ago I ran a new vacuum line (black rubber hose) to an interior gauge. As I was pulling it off the barbed fitting yesterday where it attaches to the manifold, it almost fell apart. 3 inches from the manifold, it was hard and brittle from the heat. I have a brass junction going into the intake just below the carb. It runs the vacuum modulator on the tranny and the gauge.
So the question is, what type of material should I be looking for that has some heat resistance? Or should I run a hard line for a certain distance before attaching the hose? I'm sure the hose was just something I got at the parts store and I just asked for vacuum hose. I'd like to do it right so I don't have to second guess if I'm getting vacuum leaks.
Also, should the line from the carb to the vacuum advance be a hard line? Right now it is rubber and is quite a bit smaller than the fittings on the carb and dizzy (Autolite 1100 and DSII). I'm putting a Weber DGEV on soon and will need to plumb some new fuel and advance lines anyway. I'm thinking hard lines would be better for the vacuum advance so there's no chance of them collapsing as the vacuum kicks in.
Any thoughts would be appreciated. Thanks...
