Hey Guy's
Engine : XC 250 X-flow, mild cam, extractors, 2 inch exhaust, electronic dizzy, 3 spd auto Borg Warner.
I have Just recently pulled my 350 2blr Holley apart and given it a good clean etc. When i put it back on i could'nt get the idle mix right so i took it to a carburetor bloke to have it tuned up. When i got it back from him it was idling well but out on the road it ran really bad, worse then it ever has. it is hesitant on take off it will cough and splutter if accelerated too hard, and if you accelerate slowly it would have a slight bog. i took it back and he then put 63# jets in it (from 60#) the jet change only really helped the bog durring acceleration. I still have the coughing and spluttering, and the hesitant take off, not as bad as when it had the 60# jets in, but still happens!
Anyway the carburettor block was not very helpful, he just said i don't know..... we'll leave the 63# jets in,(even though he said it was running way too rich with them) i don't know what eles is wrong he said, maybe your electric's, oh yeah and it had a low vacume reading too, your cam is causing that most likely!
Could this be electrical?, i am thinking maybe ignition coil!, As the for the low vacum, i have had this engine running really well with the same cam in it in the past, so is it really possible that the cam is causing low vacume now? The carburettor bloke said the holley is set-up properly, but i don't think he spent much time on it though!! :x
Any idea's on what could be the problem??
It is idling good though, so i'm kinda thinking the vaccum is not so bad, as i thought low vac effects idle too, right?
