crankshaft swap
Russ
Can a crankshaft from a 250 be used in a '68 200 block? If so, would the pin height in the piston need to be changed [ and if so, what other pistons would work?]?
Thanks,
Russ
Short answer = no
It would be way too much work. Even if you turn the weights down and add mallory metal to balance it, it still wouldn't work
