Lets not forget Harrie thought of fully adjustable
fabricated mounts first!, but the concept isn't new!
My mate runs a late 455 Pontiac engine in his early 400 Formula Firebird. The Pontiac engine mounts have a delightfull issue with respect to varying bolt counts. F'rinstance, the early 326/389/421/428 ones were two bolt, then the 400/455 were three bolt, then the big cars stayed as two bolt, but later, Pontiac decied it couldn't decide what it was going to do, so it went to five bolt. In many instances three holes on one side was drilled!.
Must have been the funny Indian drugs the Pontiac engineers smoked in the 70's.
Here is a fabricated set which are used for 326-350-400-455 transplants into 75 to 81 F Birds.
Any way, his simple solution to fit a five bolt engine into a 2 bolt chasiss was to add a the factory 403 Olds style flitch plate used on various models. It was a factory example of what you guys propose.
Performance Years markets the Indian Adventures kit I've shown here. The are basically super thin flitch plates, and since the engine is held in shear, strenght isn't an issue.
Back in 2003, I experiemented with moving the engine down 0.75" and back 2" when I was proposing to bolt my Rootes blow over the manifold of my old XE. There is no problem with moving it up or down, strength is not impaired in any way. There is enough room at the firewall to move the engine back, more if you use a Big Friendly Hammer and tap the fiewall join back. I'm not sure if its that easy in earlier X-shells with the braces, but there is room there even so. I spoke to the certication authority here, and he wasn't worried when he saw GM were doing it!
