It does???looks like something off the front of a mustang p51 fighter. Run an electric one!
3-row is quite a bit more cooling capacity. Eliminated all my heating issues on a pickup- in the melt-belt.Thanks for the input! Looks like most of you are running a 3 row. I was convinced there wasn't enough difference and that the 2row would give me more fan clearance. But hey might as well go 3!
With a Spectra CU1463 radiator and my stock pulley, spacer, and 6-bladed fan I have about 7/8" clearance between the fan and the radiator, a comfortable distance. And that wasn't much closer than with the original radiator in, though that was a special AC specific version too, I'm not sure if it was thicker than the standard radiator. With an after-market fan you'll be taking a chance, but you can put a shorter spacer on I suppose.I was convinced there wasn't enough difference and that the 2row would give me more fan clearance.
