so the weak spot in the crossflow enigne is the pushrods right? is there anyway to beef up the motor so it can be spun at 7k?
nick
nick
What I've found is that the stock pedestal is not that robust, so machining for studs leaves little meat for support if you drill and tap for a 7/16" stud base. Probably best to use a 3/8" stud and cut and weld 351C pushrod guides.
