Tried using the search mode, but no specificanswer. Having to drop back a few and punt as I and the car have been down since mid October. What are the steps I need to do to determine what's the compression ratio.
or you can take apart the motor to cc the head, piston dish/deck hieght and head gasket like I did. I wished I was smart enough to think of cc'ing the entire motor while it was assembled on the engine stand. You know, rotate the motor until the spark plug hole was level, the piston at TDC with both valves closed. Just measure what it takes to fill the combustion chamber right up the to bottom of the spark plug hole threads to get the entire combustion chamber volume:
Thanks for the info. Due to some gasket problems, the heads got to come back off, so I'll cc the head and the top of the piston at that time. What is ment by deck height?
