Hello, amazing site. I've spent quite a few hours reading already. I'm hoping for some insight regarding a recently rebuilt engine that sadly had two piston ruined by detonation, pre-ignition, or just plain running lean (those are my deductions/ and the extent of my mehanical experience is about 3 years and running). Perhaps the destruction of an engine, I spent $1600 3 years ago to have rebuilt, will help people learn from my inexperience. Here's some pics of pistons 2 and 3 in my 200ci (now out for a rebuild)
http://oldeconolines.com/dm1.jpg
http://oldeconolines.com/dm2.jpg
http://oldeconolines.com/dm3.jpg
The engine is in a 62 econoline travelwagon, which I've done quite a lot to make run such that it would be dependable.... oh well, live and learn. To outline a few of the upgrades, I replaced the smaller radiator with a fresh 240 radiator, Had the carb rebuilt (a motocraft carb I am told is for a 200ci : D9JL 9510JH 9170 1109) AND RE-JETTED, I also put a pertronix ignition in the dist along with a "flame thrower coil" (I believe the dist is from a 65?-that's the cap that works).
So I've got pistons 2 and 3 trashed. My thinking is this must somehow be caused by the carb, dist, or both. I'm not sure whether the carb or dist are high or low vacuum. I had the setup tuned (so I thought) by a regular shop, and they claimed the carb and dist were compatible. I don't think the water jackets on pistons 2 and 3 are clogged, or that there's any crack in the head. Perhaps there's some vacuum leak in the carb, not sure.
To be safe, my current plan (would love to consider other suggestions) is to replace both the carb and dist (I need to keep costs down so I'll probably look for inexpensive options now- like a 1940 carb rejetted- and go for a upgrade to a webber type later). I printed out the article on the Duraspark conversion, and I can do that. My essential questions are:
1) has anyone ever seen pistons 2 and 3 burn because of running lean?- Has anyone seen this situation before?
2) what id numbers can I reference to ensure I get a high vacuum Duraspark and a High vacuum 1940 carb? (or a another stock type carb)
3) any other suggestions as to what caused the piston destruction and what I can to to get set up so I won't end up a thousand miles from home with a blown engine?
I would mention also, I never heard any abnormal noises from the engine that would suggest detonation or a serious engine issue; with the exception of one occasion last summer when decelerating on a long haul, the engine started ticking loudly. I let it rest for awhile, restarted it and the ticking had reduced significantly; let it rest a bit longer and the ticking was gone. I chalked it up to a stuck lifter and got back on the road. Never having driven a late model vehicle prior to the econoline, I always assumed the way the vehicle accellerated as being the nature of the beast; but I've always had to be carefull on takeoff to avoid the bucking bronco effect or killing the engine; I am now deducing this was cause the carb was jetted too lean. For the record, the rebuilder omitted valve guides from the original rebuild, which was causing fouled plugs, so he pulled the head and did the valve guided about 3K into driving the new motor. Since then the plugs were in my opinion normal grey-brown, perhaps tending somewhat to white. Any help will be greatly appreciated....... thanks.......
