adjusted the choke, the linkages are sort of old, a bit rusty. Can they be lubricated? Runs better, still misses a bit when idling. Runs down the road fine. Sputters a bit when cruising at low speed thru town. Ignition is pertronix I.
What is correct procedure to adjust choke? I let car warm up, then adjusted choke to be wide open when warm. Will see if it works when cold. We are still having cool mornings.
I need to unhook the "carb heat", will get to that next.
Plugs were full of carbon. They are Autolite 46. I got the performane six book mentioned in this forum and I see they suggest with electronic ignition a hotter coil going to one step cooler plug and wider gap. Ths is a california smog pump car, still intact. Any guesses on which plug to use?
Also read that timing should be advance 5 degrees from normal. Any suggestions as to the stock and adjusted timing. Procedure for this would be appreciated also.
Carb is the stock autolite 1100, from what I can tell. I fooled around with a vacuum gauge for the first time today. when warmed up and idling, the vacuum was about 16. Is the adjustment screw the one at the base of the carb? I fiddled there just a little, but didn't seem to make much difference in the rough idle.
Seems to accelerate well on the road. It's the low speed and idling that needs to improve. Thanks for any comments and help.
I've debated on taking off the smog stuff. This is a real nice original california six banger that I imported to MN, including the black plate, so I hesitate to rip 'er apart, including the smog pump. Am I looney, does the smog stuff need to come off? Or, leave as is and preserve the uniqueness of this vintage aqua stang convertible?
Many thanks, appreciate ALL comments.
