Dizzy
mluck
I was in a rush to install the module in my Mallory unilite diz.one of the screws holding on the module fell..what I thought was down in the dizzy...so I took the diz.out...forgot to mark the rotor position...at top dead center..should the rotor point at number one cyl.
Remove the number 1 spark plug Put your finger or a piece of tissue paper over the number 1 hole as you turn the engine over, as its coming up on compression it will push it out. Good luck :thumbup: :nod:
Hi, Google a Ford 200 firing order diagram.
#1 is @ 5:00 o'clock position, pointing kind of at the master cylinder.
Pointing at the #1 spark plug is not right.
Good luck
